  • 1.  IAP Portal 802.1x issues%0D%0A
    Posted Aug 26, 2016 03:35 PM
    Im using IAP on the latest code. I setup my ssid to use radius for 802.1x auth. On Radius, I have EAP with a self signed cert. On a windows client, I create the wireless network, turn off "validate Cert" until I get a 3rd party one, and connect using WPA2 Enterpise. I get connected fine. Then I convert the SSID to guest, create a authenticated captive portal, point auth to radius and login keeps failing with the below error. What am I missing?
    Contact the Network Policy Server administrator for more information.
    User:
                    Security ID:                                          redbull\RSmith
                    Account Name:                                   rsmith
                    Account Domain:                                               redbull
    Client Machine:
                    Security ID:                                          NULL SID
                    Account Name:                                   -
                    Fully Qualified Account Name:        -
                    OS-Version:                                          -
                    Called Station Identifier:                   aca31ec7b99c
                    Calling Station Identifier:                  c4b301bb0dc1
    NAS:
                    NAS IPv4 Address:                              192.168.174.250
                    NAS IPv6 Address:                              -
                    NAS Identifier:                                     -
                    NAS Port-Type:                                    Wireless - IEEE 802.11
                    NAS Port:                                              0
    RADIUS Client:
                    Client Friendly Name:                        Aruba
                    Client IP Address:                                                192.168.174.250
    Authentication Details:
                    Connection Request Policy Name: NAP 802.1X (Wireless)
                    Network Policy Name:                      Aruba
                    Authentication Provider:                  Windows
                    Authentication Server:                      SDDC02.off.redbull.edu
                    Authentication Type:                         PAP
                    EAP Type:                                             -
                    Account Session Identifier:                               -
                    Logging Results:                                  Accounting information was written to the local log file.
                    Reason Code:                                       66
                    Reason:                                                 The user attempted to use an authentication method that is not enabled on the matching network policy.
  • 2.  RE: IAP Portal 802.1x issues%0D%0A
    Posted Aug 26, 2016 03:57 PM
    You need to enable PAP authentication in NPS/IAS policy for that to work
    Get Outlook for iOS
  • 3.  RE: IAP Portal 802.1x issues%0D%0A
    Posted Aug 26, 2016 05:52 PM
    I did enable it. Under authentication in the network policy on NPS. The check box under MSChap section. I also enabled EAP and EAP settings..
    Also, why is it using PAP. I want EAP only. Could EAP not be working becouse its doesn’t have a trusted Cert so PAP is being used instead?
  • 4.  RE: IAP Portal 802.1x issues%0D%0A
    Posted Aug 26, 2016 06:26 PM
    Pap is the only thing that works with Captive Portal.
