I have a 1500-24P Mobility Access Switch, and 2 IAP-215,
I would like to set up a roaming environment using these equipments.
When I watch the video of the part of roaming in the Instant training,
it have mentioned that we can add the secondary IAP to the virtual controller.
However, is it possible that I can set up roaming without the virtual controller?
cause I would like to set up the IAPs with IP assigned from the network instead of the Virtual Contoller.
It means that I would not have a virtual controller right?
