  • 1.  IAP to Campus AP conversion problems
    Posted Aug 24, 2016 09:00 PM
    Can not get an Aruba 325 AP to convert from IAP to Campus AP.  I have done both the instant UI and CLI commands.  In both cases the AP appears like it is converting but I never see it at my controller...  Here is the output of the AP after I gave it the convert command from CLI
    Attachment(s)
    txt
    AP325convert.txt   10 KB 1 version
  • 2.  RE: IAP to Campus AP conversion problems
    Posted Aug 24, 2016 09:16 PM
    AP rebooted Wed Aug 24 22:25:22 UTC 2016; Image Download Failed.
    Your controller likely isn't running a version of code that supports your AP.
    What release are you running on your controller?
    As noted in the AP datasheet, the 325 requires a minimum of AOS 6.4.4.0.
  • 3.  RE: IAP to Campus AP conversion problems
    Posted Aug 26, 2016 09:54 AM
    Thanks Tim, I think you nailed it.  We are currently running 6.4.2.12 so going to grab the firmware upgrade now.  Thank You.
