IAP VC IP address unresponsive
  • 1.  IAP VC IP address unresponsive
    Posted Jan 06, 2017 09:57 AM
    There is an issue I've come across that I've opened a case for, but wanted to start some technical discussion on. Bare with me as I want to be detailed in describing my situation.
    • At times the IAP virtual controller IP address will become unresponsive for a cluster.
    • Trying to access the GUI will fail, and pings to the VC IP address will fail.
    • Pings to the subnet default gateway are successful
    • No IP conflict issue & VC IP address is removed from DHCP scope
    • Pings from gateway to VC IP address fail (of course, no ARP entry at switch with default gateway)
    • Pings from an AP within the cluster succeed
      • result in ARP entry at switch with default gateway
      • pings from default gateway to VC IP address are now successful
      • pings from external network still fail
    • Clear arp table on switch and go back to pings from gateway to VC IP address fail
    • Reboot of master AP did not resolve the issue
    • Reboot of AP cluster resolved the issue
    This ultimately seems like a ARP and/or routing issue (reaching external networks via the default gateway). The current design does not mirror Aruba recommendations (AP management VLAN) and we are making changes to do so. However, how can this guarantee that these same issues don't appear when we make these changes? I've verified all configuration, and it is correct (Uplink vlan, switch (ProCurve) port configuration, VC IP configuration).
    Sorry, I don't have packet captures as this was a remote site from where I am at.
  • 2.  RE: IAP VC IP address unresponsive
    Posted Jan 09, 2017 10:09 AM
    Could you give us some more information about your cluster?  What type of IAPs, code version running, size of cluster etc?
    I've seen issues with VC response in clusters that are very large (ie. over  ~80 members) and have a lot of multicast traffic riding the network.
  • 3.  RE: IAP VC IP address unresponsive
    Posted Jan 09, 2017 12:56 PM
    AP-335
    6.5.0.0-4.3.0.0_56428
    14 APs in cluster.
  • 4.  RE: IAP VC IP address unresponsive
    Posted Feb 06, 2017 07:58 AM
    I have the same issue, on 6.4.4.8 (Alcatel IAP-103), 35 IAP. Very strange...
    My VC self IP is 10.xx.xx.51, le Virtual IP is 10.xx.xx.151, if i look the ARP on the gateway, there is only the 51's one but the 151 is responsive... the gateway has never register the 151's ARP, and sometimes i loose the WebUI console, the 151's ping is unresponsive during 2 or 3 minutes...
    Did you find the problem?
  • 5.  RE: IAP VC IP address unresponsive
    Posted Feb 06, 2017 09:08 AM
    I could not find the root cause of the issue. Of course, when I got TAC on a remote session, the issue did not happen as the VC IP address became responsive after taking the master AP down. We still confirmed that the old MAC address for the former master AP was still in the ARP caches of the new master AP.
    One thing that I did change before talking to TAC was upgrading to the latest code 6.5.0.0. I'm not sure what code is available since you are using the Alcatel IAP.
    I would recommend trying to upgrade the code (if update is available).
  • 6.  RE: IAP VC IP address unresponsive
    Posted Feb 06, 2017 09:12 AM
    Yes on Alcalel 6.5.0.0-4.3.0.1_57133 and 6.5.1.0-4.3.1.1_57902 is avaible too.
    It's a critical prouduction site, so we can't upgrade without testing many RF devices before.
  • 7.  RE: IAP VC IP address unresponsive
    Posted Feb 23, 2017 03:35 AM
    Does the issue occurs when the client density is high ?
    Is DPI enabled on the cluster ?
  • 8.  RE: IAP VC IP address unresponsive
    Posted Feb 23, 2017 04:08 AM
    No few clients only in this warehouse.
    It happen only when the WebUI is open...
    6.1.1# show dpi debug statistics
    DPIMGR is not enabled
    I assume DPI is not enable.
  • 9.  RE: IAP VC IP address unresponsive
    Posted Feb 23, 2017 04:15 AM
    If possible, please share the running-config from the IAP.
  • 10.  RE: IAP VC IP address unresponsive
    Posted Feb 23, 2017 04:21 AM
    6.1.1# show running-config
    version 6.4.4.0-4.2.4
    virtual-controller-country FR
    virtual-controller-key xxxxxxxxxxxxxxxxxxxxxxxxxxxx
    name xx-xx-xx
    organization xxxxxxx
    virtual-controller-ip xx.xx.xx.xx
    syslog-server xx.xx.xx.xx
    terminal-access
    telnet-server
    ntp-server xx.xx.xx.xx
    clock timezone Paris 01 00
    clock summer-time CEST recurring last sunday march 00:00 last sunday october 03:00
    rf-band 2.4
    ams-ip xx.xx.xx.xx
    ams-key xxxxxxxxxxxxxxxxxxxxxx
    ams-identity xxxxxxxxxxxxxxxxxxxxxxx
    allow-new-aps
    allowed-ap 04:bd:88:c8:e5:a4
    allowed-ap 04:bd:88:c8:e5:f2
    allowed-ap 04:bd:88:c8:e6:26
    allowed-ap 04:bd:88:c8:e5:c8
    allowed-ap 04:bd:88:c8:e6:42
    allowed-ap f0:5c:19:cc:8d:44
    allowed-ap f0:5c:19:cc:8c:1c
    allowed-ap f0:5c:19:cc:8d:2e
    allowed-ap f0:5c:19:cc:90:c4
    allowed-ap f0:5c:19:cc:90:d4
    allowed-ap f0:5c:19:cc:91:02
    allowed-ap f0:5c:19:cc:90:ca
    allowed-ap f0:5c:19:cc:90:da
    allowed-ap f0:5c:19:cc:90:ce
    allowed-ap f0:5c:19:cc:90:e0
    allowed-ap f0:5c:19:cc:90:9a
    allowed-ap f0:5c:19:cc:90:de
    allowed-ap f0:5c:19:cc:93:b6
    allowed-ap f0:5c:19:cc:93:ac
    allowed-ap f0:5c:19:cc:90:bc
    allowed-ap f0:5c:19:cc:93:b0
    allowed-ap f0:5c:19:cc:93:a6
    allowed-ap f0:5c:19:cc:93:aa
    allowed-ap f0:5c:19:cc:93:c8
    allowed-ap f0:5c:19:cc:93:a0
    allowed-ap f0:5c:19:cc:93:c6
    allowed-ap f0:5c:19:cc:8e:34
    allowed-ap f0:5c:19:cc:93:c2
    allowed-ap f0:5c:19:cc:93:b8
    allowed-ap f0:5c:19:cc:8e:2e
    allowed-ap f0:5c:19:cc:8e:40
    allowed-ap f0:5c:19:cc:8e:30
    allowed-ap f0:5c:19:cc:8d:e8
    allowed-ap f0:5c:19:cc:8e:3c
    allowed-ap f0:5c:19:cc:8d:f6
    allowed-ap f0:5c:19:cc:8e:2c
    allowed-ap f0:5c:19:cc:8e:36
    allowed-ap f0:5c:19:cc:92:ea
    allowed-ap f0:5c:19:cc:8d:34
    allowed-ap f0:5c:19:cc:8d:4a
    allowed-ap f0:5c:19:cc:8d:10
    allowed-ap f0:5c:19:cc:8d:50
    snmp-server community xxxxxxxxxxxxxxxxxxxxxx
    arm
     wide-bands 5ghz
     80mhz-support
     g-channels 1,5,9,13
     min-tx-power 127
     max-tx-power 127
     band-steering-mode disable
     air-time-fairness-mode fair-access
     client-aware
     scanning
     client-match
     client-match nb-matching 75
    rf dot11g-radio-profile
     spectrum-monitor
    rf dot11a-radio-profile
     spectrum-monitor
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    proxy server xxxxxxxxxx.dmn01.vanilla.toplevel 8080
    user 002368e4d722 xxxxxxxxxxxxxxxxxxxx portal
    mgmt-user admin xxxxxxxxxxxxxxxxxxxxx
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule wired-instant
     index 1
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule BELLENUS
     index 6
    wlan access-rule EDT-PAW
     index 7
    wlan access-rule EDT-EMP
     index 8
    wlan access-rule denyall
     index 9
     rule any any match any any any deny
    wlan ssid-profile BELLENUS
     enable
     index 4
     type employee
     essid BELLENUS
     wpa-passphrase xxxxxxxxxxxxxxxxxxx
     opmode wpa2-psk-aes
     max-authentication-failures 0
     vlan xxx
     rf-band 2.4
     captive-portal disable
     dtim-period 1
     broadcast-filter arp
     deny-inter-user-bridging
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    wlan ssid-profile EDT-PAW
     enable
     index 5
     type employee
     essid EDT-PAW
     opmode wpa2-psk-aes
     vlan xxx
     rf-band all
     hide-ssid
     dtim-period 1
    wlan ssid-profile EDT-EMP
     enable
     index 6
     type employee
     essid EDT-EMP
     opmode wpa2-aes
     vlan xxx
     auth-server xxxxxxxxxx
     set-role-machine-auth denyall denyall
     rf-band all
     hide-ssid
     dtim-period 1
    auth-survivability cache-time-out 24
    wlan auth-server xxxxxxx
     ip xx.xx.xx.xx
     port 1812
     acctport 1813
     nas-ip xx.xx.xx.xx
     nas-id BAL-SW-WIFI
    wlan auth-server xxxxxxxxxxxx
     ip xx.xx.xx.xx
     port 1812
     acctport 1813
     key xxxxxxxxxxxxxx
     nas-ip xx.xx.xx.xx
     nas-id BAL-SW-WIFI
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
  • 11.  RE: IAP VC IP address unresponsive
    Posted Feb 23, 2017 08:29 PM
    Thank you for sharing the log file.
    I do not see any specific parameters which could be leading to this.
    The config shows vlan id mapped to SSID profiles which tells me that
    mgmt/client vlan are different (which is recommended)
    I can suggest the following:
    1. Disable background spectrum monitoring on the radios.
    2. is max/min power kept at 127/127 due to any specific reason ?
    ARM profile allows you to specify different transmit powers for 2.4 vs 5 Ghz
    2. In case the VC becomes unresponsive, check if we get console access to it.
    Run a continuous ping to VC from uplink switch:
    If we get console access, collect the following:
    IAP# show tech-support
    IAP# show process
    IAP# show cpu details
    IAP# debug pkt type icmp arp
    IAP# debug pkt dump
    Along with that , we can collect VC uplink capture to determine the traffic
    pattern.
