  • 1.  IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 13, 2025 12:34 PM
    I would like to know the differences between an architecture with virtual controllers onboard the APs and a bare-metal controller. Is it only the number of manageable controllers that changes? When using bare-metal controllers, is it possible to create and manage an arbitrary number of clusters, or is AirWave still required, with each controller managing only one cluster?
  • 2.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 13, 2025 01:03 PM
    Airwave is a good valueadd for Historical data logs, Monitoring and in some cases management. But since airwave is moving gradually to Central, in that case you can have Central or Central OnPrem.
    As for the controllers, depends what you want to achieve, what type of deployment will you do, cost, etc.
    For virtual, you need to have Server + Hypervisor in order to have controllers running and also a lot of additional work to do connectivity, port configuration of server infrastructure etc.
    For Baremetal Controllers, you have everything in a box with less headache and simplified to be up & running with less headache.
    Performance wise and numbers you can find on here:
    https://www.hpe.com/psnow/doc/a00059064enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00059063enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00059069enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00059060enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00121209enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00134298enw?jumpid=in_pdfviewer-psnow
    https://www.hpe.com/psnow/doc/a00067608enw?jumpid=in_pdfviewer-psnow
    Personally, for customers who have well established Server infrastructure, i recommend to purchase Virtual. For end customers who don't have a well structured Datacenter, Redundancy, Licensing of Hypervisors, etc. i recommend bare metals. But there are other things which have to be taken into consideration as well.
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 14, 2025 02:58 AM
    Sorry, I didn't explain myself well. Today, I have various architectures with different types of IAPs managed by AirWave and multiple clusters centrally managed by AirWave, where I use the same APs as virtual controllers for each cluster. If I were to integrate virtual controllers like the 8360, could I eliminate AirWave since they are capable of managing multiple clusters, or can a physical controller manage only one cluster, meaning I would still need to use AirWave?
  • 4.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 14, 2025 03:55 AM
    Hi.
    I believe you are mixing terms here. Instant only has Virtual Controller hosted on one of the APs. Mobility HW/Virtual controllers/gateways are completely different beasts and can't manage Instant APs virtual controllers. MDs (Managed Device) controllers/gateways can be configured in clusters that are managed ba MM (Mobility Conductor). Mobility Conductor can manage many MD clusters. APs are connected to MDs via tunnels and use different FW downloaded from controllers than Instant APs.
    You use Instant clusters If I read your post correctly. If you want to manage more than one VC cluster from one place you need AirWave or Central or Central OnPrem to do it.
    By 8360 do you mean an ArubaCX 8360 switch or you have a different beast in your mind? HW controllers/gateways are 7xxx (obsolete now) or 9xxx series. switch can't control APs.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 5.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 14, 2025 04:52 AM
    excuse me not 8360 but 9240. Ok this is the problem: now i've 4 cluster with vc instant controller managed by airwave.  if i buy one  9240 i can remove airwave and manage the 4 cluster via 9240 or 9240 are  only a wifi-controller and can't manage more then 1 cluster?
  • 6.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 14, 2025 05:09 AM
    NO.
    Please read carefully what I wrote in reply.
    Instant APs are ALWAYS managed by Virtual Controller inside the AP. One AP is elected as controller for the cluster.
    9240 is a HW controller to manage CAMPUS APs. All new APs are universal, can be campus or instant; depend on FW.
    AirWave is management tool not a controller. It has a capability to manage different network devices and provide historic data about how your network is performing amongst the other things. You can have AirWave on bare metal if you wish.
    If you really like to get rid of AirWave and multiple Instant Virtual Controllers, you have several options.
    1. Go to AOS10 and Aruba Central. Then you wont have any VC and you will be able to manage all locations and all APs from central dashboard. Requires Central subscription for each device.
    2. Deploy HW/Virtual controllers in MM/MD (Mobility Conductor/Managed Device) configuration and convert all APs to campus APs. Require license bundle for each AP. And require carefully planning as it is possible, that you will need more than one controller cluster for your situation. And a least two controllers and one conductor.
    3. Go to Central on Prem if your configuration is big enough.  Require HW server to host COP and Central subscriptions for each AP.
    All of this options can become quite expensive compared to AirWave. The cheapest one is 1.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 7.  RE: IAP Virtual controller vs bare metal controller and Airwave
    Posted Feb 14, 2025 07:05 AM
    With all this confusion, and because 9240 are for quite large networks so your network may be quite large, I'd strongly advise you to involve your HPE Aruba Networking partner in the discussion or invite the local SE/Sales team to go over the options, pro/cons, and get to an optimal design.
    Making a decision based on what's discussed in this forum based on partial and even possible partial incorrect information sounds like a big risk if you want a stable and performing network in the end.
