  • 1.  IAP-VPN scalability for IAP-200 / 210 series
    Posted Apr 11, 2016 12:33 AM
    Hi All,
    In the Aruba Instant VRD, there is a table which outlines the VPN throughput for instant access points. This shows the IAP-225 but not the newer 205 / 215 models.
    Can someone please advise the rated VPN throughput for these models?
    Scott
  • 2.  RE: IAP-VPN scalability for IAP-200 / 210 series
    Posted Apr 11, 2016 02:53 AM
    Scott,
    Good catch; I will ask the VRD developers to include the newer APs in the VRD.
    In the mean time, I would count with 25Mbps for the 205, and 40Mbps for the 215... If I get better numbers, I'll let you know.
    Herman
  • 3.  RE: IAP-VPN scalability for IAP-200 / 210 series
    Posted Apr 11, 2016 09:39 PM
    Thanks Herman!
  • 4.  RE: IAP-VPN scalability for IAP-200 / 210 series
    Posted Apr 12, 2016 03:31 PM
    205 28 Mbps
    215 43 Mbps
    205H 33 Mbps
    325 153 Mbps
    Thanks.
  • 5.  RE: IAP-VPN scalability for IAP-200 / 210 series
    Posted Mar 17, 2022 02:04 PM
    Hi mannvishal,
    Where did you find those number, are there any new models on this list? I'm looking for the IAP 535.
    I have test IAP 305, speed is like the 325.
    Pat
    Patrick Casavant
  • 6.  RE: IAP-VPN scalability for IAP-200 / 210 series
    Posted Apr 19, 2022 08:23 AM
    You responded to a very old post. IPsec encryption throughput is available in the AP datasheet or on the 'Compare AP' feature on the Aruba website.
    Alternatively, the Validated Reference Design guide for Aruba Instant or IAP VPN, should contain these numbers as well. On modern APs these VPN throughput numbers are quite high, even on the lower end APs.
