You can try setting the "Can be used without uplink" setting under the SSID (3.3 and higher).
You may need to convert the IAP to a Standalone AP to make this work. Maintenance --> Convert --> Standalone AP. If you do this, you may also need to set the uplink to Ethernet under Settings --> Uplink --> Uplink Preference. Set the network up before converting it.
