  • 1.  IAP305 Firmware Upgrade
    Posted Aug 27, 2021 04:06 PM
    This has probably been asked before but  here I go - can you update the firmware on a IAP305 without a contract.  The internal check for new firmware doesn't work and it is really had to determine if I can download the file manually.  When I try from the support site it says something about "HP will contact me in 2 days...." and doesn't let me download it.
    Mark
    Mark Smith
  • 2.  RE: IAP305 Firmware Upgrade
    Posted Aug 27, 2021 08:04 PM
    Aruba Limited Lifetime Warranty software can be downloaded from the Aruba Support Portal (asp.arubanetworks.com) without requiring a login
    check this link
    https://asp.arubanetworks.com/downloads;pageSize=100;search=factory;fileTypes=SOFTWARE;products=Aruba%20Access%20Points
  • 3.  RE: IAP305 Firmware Upgrade
    Posted Aug 28, 2021 05:01 AM
    Hi Mark
    Similar situation for me - see my thread
    Unable to download Aruba 103 latest firmware
    Rob
    rob rancans
  • 4.  RE: IAP305 Firmware Upgrade
    Posted Aug 31, 2021 08:46 PM
    try this link
    https://asp.arubanetworks.com/downloads;pageSize=100;search=factory;fileTypes=SOFTWARE;products=Aruba%20Access%20Points;productSeries=Aruba%20103%20Series%20Campus%20Access%20Points
  • 5.  RE: IAP305 Firmware Upgrade
    Posted Aug 31, 2021 09:25 PM
    Thanks. That worked.
  • 6.  RE: IAP305 Firmware Upgrade
    Posted Sep 01, 2021 01:24 AM
    Thanks for the webpage - I was able to download it and apply it successfully.
    Mark
  • 7.  RE: IAP305 Firmware Upgrade
    Posted Sep 01, 2021 10:33 AM
    Thanks for the info. I was able to download and apply successfully.
