  • 1.  IAP325 : modify the wifi range
    Posted Jul 12, 2017 11:32 AM
    Hi everybody!
    First of all, i'm fairly new with aruba network and english is not my native language, so please, be kind!
    For my new job, i've to add a Wi-Fi network to the building. My boss don't want that the network spreads too much outside the building. So, i'm looking for a solution to reduce the range of the AP. We use an Aruba IAP325 for the tests.
    I tried to modify the settings in "RF/Advanced options/RADIO" and set those options:
    • 2.4GHZ --> Min 3. Max 12.
    •  5GHz --> Min 3. Max 12.
    But it seems it doesn't change anything for the wifi range.
    What am i missing ? Are there any options that could resolve my problem?
    I hope i have explained my problem as clearly as possible.
    Thank you!
    Regards.
  • 2.  RE: IAP325 : modify the wifi range
    Posted Jul 12, 2017 11:35 AM
    Can you see what the transmit power on each band is for that AP on the dashboard?
  • 3.  RE: IAP325 : modify the wifi range
    Posted Jul 12, 2017 11:54 AM
    Where can i find those informations?
    I use the version 6.4.4.4-42.3.0-54225 if this can help...
    Thank you for your fast answer btw.
  • 4.  RE: IAP325 : modify the wifi range
    Posted Jul 12, 2017 12:25 PM
    The front page should list all of the access points and their current transmit power...
  • 5.  RE: IAP325 : modify the wifi range
    Posted Jul 13, 2017 03:17 AM
    See the attached file, i only got those information on the dashboard.
    EDIT : See also the txt file containing the command #show ap debug driver-config
    Thank you.
    Attachment(s)
    txt
    log ap.txt   47 KB 1 version
