  • 1.  IAP335 APB Beacon not working
    Posted Jun 14, 2022 03:11 PM
    I am setting up an Aruba IAP335 controller. Trying to test the BLE IoT service (using WebSocket). I have set up and used both radio-profile and transportProfile.
    Aruba_ap1# show running-config | include iot
    iot radio-profile test
    iot transportProfile chorus_test
    iot use-radio-profile test
    iot useTransportProfile chorus_test
    I also set up my WebSocket server and can receive some beacon. However, the beacon has no BleData included. It only contains the following data:
    meta {
      version: 1
      access_token: "aabbccddee"
    reporter {
      mac: "......"
      ipv4: "192.168.1.93"
      hwType: "AP-335"
      swVersion: "8.8.0.0-8.8.0.0-mm-dev"
      swBuild: "77366"
      time: 1655077928
    Don't know what's going on. One thing I noticed is that the APB seems to be disabled (see the information highlighted below). Even although I chose "Beaconing" option.
    Radio Configuration
    Item                          Value
    Radio Information             TI ONBOARD Internal BLE
    Radio Profile Type            --
    Zigbee Supported              No
    APB MAC Address               f4:5e:ab:bb:49:87
    Operational Mode              Beaconing (APB: Disabled)
    Operational BluOS FW Version  OAD B 1.2-42
    Bundled BluOS Upgrade         Enabled (-1)
    Bundled BluOS Images          Bank A(/aruba/bin/UpgradeImage_AP_OAD-A_1.2-42.bin) Bank B(/aruba/bin/Beacon_AP_OAD-B_1.2-42.bin)
    OTA FW BluOS Upgrade          Disabled
    FW Stack Supported            No
    Don't know if this is the root cause and how to solve it. Any suggestions? Thtanks!
  • 2.  RE: IAP335 APB Beacon not working
    Posted Jun 18, 2022 07:21 PM
    what instant version are you running?
    see if this command gives you any ideas about where the issue is.
    show ap deb ble-relay disp-attr all
  • 3.  RE: IAP335 APB Beacon not working
    Posted Jun 19, 2022 11:56 AM
    Interestingly, I made no changes in the past few days and only turned off the Aruba AP. After I turned it on, the APB beaconing is working. Last week, I thought about rebooting the device may help before and I did the reboot, but still have the same issue. Looks like I just need to let the device to be quiet for some time, and it can fix the APB itself. That's really strange.
    Aruba_ap1# show iot radio-profile test
    References          :1
    Instance            :internal
    Mode                :ble
    BLE Opmode          :scanning beaconing
    BLE Console         :on
    BLE TxPower (dBm)   :0
    Zigbee Mode         :coordinator
    Zigbee Channel(s)   :auto
