I was wondering if anyone could offer any advice. I have a cluster of 18 AP505s running via Aruba Central, when I try and add another AP505 to the existing cluster (same firmware, same trunk native vlan on the switch port as all the other APs) it doesn't add and becomes a cluster of 1. I have hard reset the AP but it constantly does the same.
Finally after a day it found its way into Central but a separate VC.
Does anyone have any idea how I can get the AP to join the existing cluster so it can be used?
What would happen if I tried to change the VC Key on it to the key on the correct VC - would this mess the existing ones up as well or would this allow the rogue AP to connect up?
I've had a TAC query open for a few weeks but don't seem to be getting very far with it, so thought I'd see if anyone had any helpful suggestions on here as you've always been very helpful.
Many thanks in advance
Jo
Jo Tomasso
