  • 1.  IAP's not joing virtual cluster/dropping off
    Posted Jun 01, 2022 04:34 PM
    Edited by RedOrion Jun 01, 2022 04:50 PM
    I have 3 IAP-225-US running 8.6.0.2. They used to be joined to a virtual cluster and then randomly dropped out of the cluster. They are on the same switch and can ping each other. They all have the same virtual-controller-key. They also allow auto join of new aps. I have another cluster of the same ap's working without issue.
    Edit:
    show ap debug cloud-server
    IAP mgmt mode :local-mgmt
    cloud config recved :FALSE
    autojoin mode :disable
    state diff :disable
    Device Cert status :SUCCESS
    But "Auto join mode" is enabled in the gui...
  • 2.  RE: IAP's not joing virtual cluster/dropping off
    Posted Jun 03, 2022 02:41 PM
    Can you check if there is any other IAP in your L2 network that's acting as a virtual controller.
    Lokesh Gajendran
  • 3.  RE: IAP's not joing virtual cluster/dropping off
    Posted Jun 03, 2022 06:19 PM
    There are no other IAP's/controllers on the same L2 network. There's a separate cluster running on a separate L2 vlan that routes between each other but it's running 6.4.4.8. Would that be an issue with this formerly working cluster running 8.6.0.2?
