see if this 3x part series on RADSEC helps you.
Original Message:
Sent: Feb 03, 2025 02:19 AM
Subject: IAPVC to Clearpass 6.12 help - unknown CA SSL error
Did you installed the CA certificate on the IAPVC and configure it to for used for RadSec?
Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Feb 03, 2025 12:14 AM
I am trying what I thought was a fairly simple scenario - new CPPM 6.12 in Azure, a 510 AP running 8.12, both configured with certs signed by the same CA, and both intermediate and root CA certs added. I'm trying to get Radsec setup but so far all I get is errors in CPPM / Monitoring / Event Viewer saying:
TLS connection couldn't connect for Client IP x.x.x.x: and Port 2083 Errors: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca
Based on a few threads here I checked the IAPVC certs. Iniitally as it made me import the radsec cert as a full chain pem file I hadn;'t added the root and intermediate certs but have since done that as well. The settings for radsec on either end are fairly basic and close to defaults.
Any suggestions, or ideally a walk-through for this setup between Aruba wireless and Clearpass for RadSec?
