AOS-CX Switch Simulator
  • 1.  ICMPv6 Type in IPv6 ACL AOS-CX 10.14
    Posted 25 days ago
    Hy Community,
    I'm working on IPv6 security. I've created the following ACL.
    When I execute ICMPv6 type 3 (Time Exceeded) attacks, the rule matches ACE 110. Another case occurs when I execute an ICMPv6 type 1 (unreachable) attack from a host with address 2001:db8:20::10 to another host 2001:db8:20::11. The traffic is not filtered, and the attack is successful. It seems the rule doesn't evaluate the ICMP-type condition.
    Is this due to some simulator limitation? My configuration is:
    conf t
    nd-snooping enable
    access-list ipv6 sec
    100 permit icmpv6 2001:db8:20::/64 2001:db8:20::/64 icmp-type echo
    110 deny icmpv6 any any icmp-type 1 log
    120 deny icmpv6 any any icmp-type 3 log
    130 deny icmpv6 any ff02::1 icmp-type echo log
    exit
    vlan 20
    nd-snooping
    exit
    interface 1/1/1
    no routing
    vlan trunk native 20
    nd-snooping trust
    no shutdown
    exit
    interface 1/1/2-1/1/5
    no routing
    vlan access 20
    apply access-list ipv6 sec in
    no shutdown
    exit
     show version
    AOS-CX
    (c) Copyright Hewlett Packard Enterprise Development LP
    Version      : Virtual.10.14.1000
    Thanks a lot
  • 2.  RE: ICMPv6 Type in IPv6 ACL AOS-CX 10.14
    Posted 24 days ago
    When you say "Is this due to some simulator limitation?" do you mean that you are running this on GNS or EVE-NG?
    Issue could be that many of these platforms do not process ICMPv6 traffic at the control plane with full fidelity, especially regarding type-specific ACL evaluations.
    Also, ACL rule 100 permits echo requests. If the ICMPv6 Type 1 (Destination Unreachable) is somehow misinterpreted as not matching any specific "icmp-type", and no more specific deny is hit, it might be permitted by default ACL behavior.
    110 deny icmpv6 any any icmp-type 1 log should then block it.
    So either the icmp-type match is bugged in the simulator, or it is not actually ICMPv6 type 1 (possible misinterpretation by the tool generating the attack).
    Try positioning this rule: 90 deny icmpv6 any any log and check if this will block everything and then you can confirm whether if its a bug in the simulator or something else.
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: ICMPv6 Type in IPv6 ACL AOS-CX 10.14
    Posted 23 days ago
    Edited by ernestosv73 23 days ago
    Dear Shpat,
    Thank you very much for your response.
    I'm using Containerlab, (https://containerlab.dev/manual/kinds/vr-aoscx/) to create the network topology, integrating vrnetlab to run the aruba-cx VM inside a container. I've tested the same topology in GNS3, and the behavior is the same. Following your advice, I added ACL 90 deny icmpv6 any any log, and it effectively blocks all ICMPv6 traffic.
  • 4.  RE: ICMPv6 Type in IPv6 ACL AOS-CX 10.14
    Posted 23 days ago
    This for sure must be something related to the fact that Virtualized environment do not process ICMPv6 traffic at the control plane with full fidelity, especially regarding type-specific ACL evaluations.
    In your case, i would add the following line (marked in Bold):
    140 deny icmpv6 any any log
    exit
    And that should solve it somehow.
  • 5.  RE: ICMPv6 Type in IPv6 ACL AOS-CX 10.14
    Posted 23 days ago
    Thank you very much again. I feel better knowing it's not a mistake in the rule configuration.
    Regards
