Wired Intelligent Edge
IGMP Aruba 2920 multicast problem
  • 1.  IGMP Aruba 2920 multicast problem
    Posted Apr 07, 2018 06:18 AM
    hello
    I have a problem on iptv system, TVs has connection to ip tv video server, clock info, channel names are ok but video cannot be watch. it is all black screen. there is an Access point (ruckus zf7025) between switch and tv, when I reset AP it shows video again and everyting returns normal. but so many reset request is a big problem for me.
    I thing I have mismatced smthng on İGMP. I have hp 5400  backbone sw and aruba 2920 edge switches. whiich  has poe ports for access points.
    when I check IGMP on an edge switch I see  (querrier value allways zero in all swtiches.)
    switch-12-floor-14-A# sh ip igmp vlan 4
    IGMP Service Protocol Info
    Total VLANs with IGMP enabled : 1
    Current count of multicast groups joined : 1
    IGMP Filter Unknown Multicast: Disabled
    IGMP Filter Unknown Multicast Status: Disabled
    VLAN ID : 4
    VLAN Name : IPTV
    IGMP version : 2
    Querier Address : 172.19.255.100
    Querier Port : 48
    Querier UpTime : 4d 3h 13m 47s
    Querier Expiration Time : 0h 3m 17s
    Active Group Addresses Type Expires Ports Reports Queries
    230.1.1.25 Filter 0h 3m 23s 1 16683 0
    when I check counters
    switch-12-floor-14-A# sh ip igmp vlan 4 counters
    IGMP service Vlan counters
    VLAN ID : 4
    VLAN Name : IPTV
    General Query Rx : 5949
    General Query Tx : 0
    Group Specific Query Rx : 0
    Group Specific Query Tx : 0
    V1 Member Report Rx : 0
    V2 Member Report Rx : 0
    V3 Member Report Rx : 27857
    Leave Rx : 0
    Unknown IGMP Type Rx : 0
    Unknown Pkt Rx : 0
    Forward to Routers Tx Counter : 27857
    Forward to Vlan Tx Counter : 5949
    Port Fast Leave Counter : 0
    Port Forced Fast Leave Counter : 0
    Port Membership Timeout Counter : 0
    tx is allways zero.
    this is my config on all swtiches.
    switch-12-floor-14-A# sh run vlan 4
    Running configuration:
    vlan 4
    name "IPTV"
    tagged 1-16,18-25,48
    untagged 17
    no ip address
    ip igmp
    exit
    my querrier swtich is cisco, different then my Backbone HP swich. what do you think? my igmp works normal or not?
    regards
  • 2.  RE: IGMP Aruba 2920 multicast problem
    Posted Apr 08, 2018 04:01 PM
    hello,
    I will make my question more simple
    switch# sh ip igmp vlan 4
    Current count of multicast groups joined : 6
    VLAN ID : 4
    VLAN Name : OTRUM-IPTV
    IGMP version : 2
    Querier Port : 48
    Querier UpTime : 9d 11h 50m 53s
    Querier Expiration Time : 0h 3m 58s
    230.1.1.25 Filter 0h 4m 6s 14 54 0
    230.3.1.8 Filter 0h 4m 8s 4 12 0
    230.3.1.32 Filter 0h 4m 6s 11 93 0
    230.3.1.113 Filter 0h 4m 4s 15 281 0
    230.3.1.119 Filter 0h 4m 7s 9,20 114 0
    230.3.1.128 Filter 0h 4m 10s 13 5 0
    queries part is all "0" as you can see above. is this normal in an ip tv system?  or is it a clue that my igmp is not working proper. ip tv screens allways freez and I am tring to investigate the incident.
