Network Management
  • 1.  IMC 7.0 installation problem - Server2008
    Posted Nov 29, 2013 04:35 PM
    I am trying to set up IMC 7.0 on a Server 2008 R2(x64) system with MySQL 5.5, but having some problems when the installation tries to validate the database setup.
    The following error occurs during the check-up:
    Checking Database Parameter Configuration...
    Not Passed
    The following database parameters do not meet the installation requirements. Please modify the configuration according to the iMC MySQL database installation and configuration guide and try again: max_connections
    I have followed the installation guide for MySQL 5.5 and have re-installed it 2 times. The max_connections setting in the my.ini is max_connections=200. Is this a known problem and/or is there a solutions for this?
    Thanks in advance.
    Edit: max_connections typo
    #max_connections
    #IMC7.0
    #Installationproblems
    #mysql
  • 2.  RE: IMC 7.0 installation problem - Server2008
    Posted Nov 29, 2013 10:28 PM
    You seem to have a typo there - the parameter is max_connections = 200, but you've put max_connection = 200.
    Is that a typo in your config file, or just in the post here?
  • 3.  RE: IMC 7.0 installation problem - Server2008
    Posted Nov 30, 2013 07:52 AM
    Thanks for your quick respond.
    Unfortunatly it was a typo in my post and not in my script.
  • 4.  RE: IMC 7.0 installation problem - Server2008
    Posted Nov 30, 2013 09:59 PM
    >Unfortunately it was a typo in my post and not in my script.
    You can correct it by using Post Options > Edit Reply
  • 5.  RE: IMC 7.0 installation problem - Server2008
    Posted Jul 04, 2014 06:32 AM
    Did anyone ever discover a solution to this issue? I'm in the middle of an IMC installation on Windows and having exactly the same problem with the install script checking the max_connections setting.
  • 6.  RE: IMC 7.0 installation problem - Server2008
    Posted Dec 11, 2014 11:51 AM
    Where did you change this parameter?
    It should be as the manual says in _ProgramData_ and not in Program Files (x86) \. .\my.ini
    "The default configuration file my.ini in the data path for the MySQL server determines the functions
    and performance of the MySQL server. The default data path for the my.ini file is
    C:\ProgramData\MySQL\MySQL Server 5.5."
    You can verify if the parameter was actually changed within MySQL:
    C:\>mysql -u root -p
    Enter password: ********
    Welcome to the MySQL monitor. Commands end with ; or \g.
    [...snip...]
    mysql> select @@max_connections;
    | @@max_connections |
    | 400 | <<<
    1 row in set (0.00 sec)
    mysql>
    Please be careful and don't copy/paste the parameter. Find it in my.ini and change it.
