Network Management
  • 1.  IMC 7.3 Finally Released
    Posted Jan 27, 2017 11:11 AM
  • 2.  RE: IMC 7.3 Finally Released
    Posted Jan 27, 2017 07:10 PM
    There is a very clear warning when you install, but be sure to read the release notes.  The delay was due to a Windows update on the DB server side (MS SQL) that caused issues with database connectivity for IMC.  Details and fix procedure are in the release notes.  Although there is a very clear warning and 2 windows you have to click through during the install to warn you of the issue.
  • 3.  RE: IMC 7.3 Finally Released
    Posted Mar 03, 2017 04:41 PM
    The release notes refer to this doc regarding how to fix the Windows update/SQL problem.
    After running the tool referenced in that document, I got a result of "Check does not pass, the server has joined a domain". The fix for this is to fix the SQL server as well as "make sure the two problem cipher suites are disabled on the domain server".
    For further clarification, does "domain server" mean the directory server (Active Directory DC) for the domain, or does it refer to the server on which the IMC platform is installed?
    Thanks!
  • 4.  RE: IMC 7.3 Finally Released
    Posted Nov 06, 2017 04:22 PM
    Did you ever get an answer to this? Or did you apply a domain policy to just this server?
