Network Management
  • 1.  IMC - Device group
    Posted Nov 25, 2020 10:27 AM
    I've got problems with IMC 7.3 since upgrading in E0705P07 from E0605.
    My Devices Groups use Designated Rule such as Designated Network (range of IP) or System Name (with portion of device label) to add automatically new device in them.
    When I click on Run Auto Add Device Rule in the Device Group menu, no more new device is added.
    I can only add manually a new device since the software upgrade.
    Does anyone have the same issue?
    Thanks.
  • 2.  RE: IMC - Device group
    Posted Nov 27, 2020 04:42 AM
    I've tested this on E0705P07, and it looks like the rules are not working properly when you have both a network segment and hostname in the designated rule. My rules are working if I specify only a network segment OR a part of the hostname. Could you try that and see if it works?
    Please also open a support case for this issue, as it definitely looks like it's a bug on E0705P07.
  • 3.  RE: IMC - Device group
    Posted Nov 30, 2020 05:48 AM
    Hello Jguse,
    You're right, both network segment and device label don't work.
    I will see to open a case.
    Thanks.
