Network Management
  • 1.  IMC Monitoring of Closed site
    Posted Jan 20, 2025 06:19 AM
    Does anyone have an idea how to find out that some site which is monitored by IMC is not in use anymore?
    Swiches are  up and runnig, but there is no active devices connected to swiches...(access ports)
    Brgds,
    Anssi Laitinen
  • 2.  RE: IMC Monitoring of Closed site
    Posted Jan 21, 2025 02:15 AM
    Hi Anssi,
    if I understand you correctly, your goal is to check if the switches are connecting servers and PCs and if there is traffic on these ports. If yes, this can be achieved if you add appropriate interface monitors on the switches from the site. Navigate to Performance Management - Monitoring Settings - Add Monitor - choose Monitoring Device (Select Index) - Add under System-Interface Statistics the measurements that will fit your requirements (for instance receiving and transmitting rates), then add the devices and on the bottom of the page you will find for which interfaces the settings will apply, select Interfaces connected to servers and PCs, this way you can see if there is users are generating traffic on the switch ports.
    Thank you,
    Ivaylo
