Network Management
  • 1.  IMC on RHEL6.1 iMC-NME-PERF - Performance Management Error (or Oracle Requiement) ?
    Posted Mar 11, 2013 01:54 PM
    Looking on log files I found the following error:
    On "dmalog.txt":
    2013-03-11 13:48:31 [ERROR] [SwingWorker-pool-1-thread-5] [com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker::doInBackground(902)] Execute database script error! return value: 4. For details, see log file: /etc/iMC-Reserved/log/dbresult_2013031113482916.log
    On the dbresult_2013031113482916.log:
    ===========SFLOW Create Table ==============
    Creating table tbl_nta_conv10mins_if
    Table created.
    create bitmap index ix_tbl_nta_conv10mins_if on tbl_nta_conv10mins_if (collection_time, dev_ip, if_index, is_in)
    ERROR at line 1:
    ORA-00439: feature not enabled: Bit-mapped indexes
    Searching on web I found some comments that "bit-mapped indexes" requires Oracle Enterprise, but the IMC documentation does not reffer to it, the closest one it's the step on Oracle installation guide where "Enterprise edition" should be selected.
    It's required to install the Performance Management Module ?!
    TIA,
    Felicio Santos.
  • 2.  RE: IMC on RHEL6.1 iMC-NME-PERF - Performance Management Error (or Oracle Requiement) ?
    Posted Mar 11, 2013 07:48 PM
    You're not having much luck, are you?
    It looks like that component is used for sFlow/NetFlow analysis with the NTA module. If you're not planning on using that, then you might be OK, but I couldn't guarantee it.
  • 3.  RE: IMC on RHEL6.1 iMC-NME-PERF - Performance Management Error (or Oracle Requiement) ?
    Posted Mar 12, 2013 03:52 PM
    Definitely the thousands of pages of IMC manuals leave some deployments depending of luck really !
    Fortunately (or not), I got approval to restart the deployment on Windows so I think now I will run smoothly and does not bother you my friend (at last I hope so).
    Thanks for your attention!
    Sincerely,
    Felicio Santos.
  • 4.  RE: IMC on RHEL6.1 iMC-NME-PERF - Performance Management Error (or Oracle Requiement) ?
    Posted Mar 12, 2013 04:40 PM
    You should be fine on Windows - or at least I know I can help out if you're having problems.
    If you're doing a remote SQL Server install, there are a few things to watch out for with the install, but I think I've seen most of them, so we should be able to resolve any issues.
