Hi, if so (reading about what HPE told you) what your HPE IMC E0710P04 suffered could be an "unknown bug" (unknown before present...unknown to HPE Support...so something never reported before to them by HPE IMC users).
If it is really a new bug never discovered before (and thus never fixed), it could be potentially capable of hitting the P06 and the H08 software releases too.
Strange but not impossible (especially if it is not tied to your particular deployment but it is really only application specific).
Original Message:
Sent: 6/2/2025 12:15:00 PM
Subject: RE: IMC. Problem with backups of managed switch configs (Is it a bug?)
Thank you for suggetion. But as I heard from HPE support there is no such case before and upgrade won't solve described issue. I wonder if anyone encountered such problem and what could be the reason?
Original Message:
Sent: Jun 02, 2025 07:03 AM
Subject: IMC. Problem with backups of managed switch configs (Is it a bug?)
Hello, you should update your patched HPE IMC 7.3 E0710P04 (P04) to latest Patch E0710P06 (P06) of late 2024 or to latest Hot Fix E0710H08 (H08) releases few weeks ago. Cheers.
Original Message:
Sent: 6/2/2025 6:30:00 AM
Hello. I have a problem with IMC 7.3 (e0710p04). This is a problem with backups of managed switch configs.
The essence of the problem: backups worked as they should until April 27, 2025. After that, for no apparent reason, 99% of backups were not made. It was decided to restart the IMC Server on May 30 - and backups started working as they should again. I may encounter this problem again in the future.
Dear friends, have you encountered such a problem? Do you think this is an IMC bug?
