Network Management
  • 1.  IMC report how long are unused interfaces down?
    Posted May 11, 2015 07:49 AM
    is there a way to get a report how long unused interfaces were down?
    or when there was last time traffic on it.
    we have iMC PLAT 5.2 and HP 5120-48G-EI-2SLOT Switches.
    thanks
    regards
    Markus
  • 2.  RE: IMC report how long are unused interfaces down?
    Posted Aug 10, 2015 07:54 AM
    We would need such a report too. Any ideas out there?
    Stefan
    (IMC PLAT 7.1)
  • 3.  RE: IMC report how long are unused interfaces down?
    Posted Aug 13, 2015 04:14 PM
    You could do something like this if you have the Reporter license, and write a custom report for it.
  • 4.  RE: IMC report how long are unused interfaces down?
    Posted Aug 18, 2015 05:00 AM
    Hello Markus,
    you might try the following:
    go to the Report | Report Template List and select the "Interface Connectivity Summary Report". There you select a time frame (i.e. 90 days). In the report you will find the coloum "Total Break Persistance", which will tell you the minutes the interface was down. If this value is 60 x 24 x 90 = 86400 Minutes you know that this interface is not in use for at least 90 days.
    Keep in mind to set the configuration poll intervall to an appropriate value.
    Best Regards,
    Michael
