Network Management
  • 1.  IMC SQL SA Password Prompt
    Posted Nov 07, 2017 11:02 AM
    Hey there,
    Apologies if this questions may sound stupid, first time posting and really using IMC. I've attempting to install onto a customers server running Windows server 2016, when installing IMC directly with an embedded SQL it promps for the SA password, however I've tried with what I believe to be the SA password by default that IMC creates but this doesn't do anything.
    I believe the default SA password should be IMC-Install2008, but its not happy about this.
    Many thanks in advance!
    Steven
    #Password
  • 2.  RE: IMC SQL SA Password Prompt
    Posted Nov 08, 2017 01:33 AM
    the default sa password is iMC-Install2008 (I think you tried with capital I)
    you can check this here:  <imc depot>/windows/install/components/common/db/install64.bat
    please note that windows server 2016 is not supported by IMC yet
  • 3.  RE: IMC SQL SA Password Prompt
    Posted Nov 08, 2017 10:01 AM
    Great thanks, I'll give that a go! Do you know possibly when Windows Server 2016 might be fully supported?
    Steven
