Become a Member
I have a customer using IMC with SQL 2012
Now customer is upgrading his SQL to SQL 2016 SP1
DOes IMC support SQL 2016 or at least SQL 2014 ?
Check the "Installation Prerequisites" section of the Readme for the IMC version your customer is using. e.g. this is the latest README: http://h20565.www2.hpe.com/hpsc/doc/public/display?docId=a00018447en_us
That lists supported DB versions.
does it work on SQL 2016 sp1 on windows server 2016 , cause SQL 2016 works on windows server 2012.
