Hi All,
Just getting back to this today... We have the SQL client setup correctly. We added in a path on VM to the SQL db.
But it failed on connectivity test so unable to progress with the install.
To make some progress we decided to just use the local embedded SQL as the DB will not be that big. It would have been better to have the DB on the SQL server but after reading lots of manuals, opening a support ticket we still could not get it to work.
Now we thought this wil be simple and straight forward but alas we now have another problem.
We un-installed any reference to SQL and IMC.
Started a fresh install on the VM and it installed the embedded SQL and then installed the IMC platform.
But when it tried to deploy the components it fails.
It directs us to a log file in temp directory which seems to fail on deploying to Slave. We are not using any Master/Slave scenario so uninstalled again and tried again. After 3 attempts, still it will not deploy any components. The same error all the time. "slave deploy failed". An absolute disater of a day!
We are installing on Win 2012 R2 Standard with 6GB of RAM allocated.
We are using V7.1 (303) and if succesful will be updating to latest patch.
Has anybody else experiened issue with deploying components? I have used this verison on 2 other installs over the summer without issue.
