Could someone please paste working configuration of 802.1x and SSH admin login with IMC UAM to Aruba OS-CX, in my case its 6100 with newest firmware.
I have devices with ComWare OS, how this works is and what I expect is to be able login to switch with Admin priviliges added to IMC as the Device User:
I've found some docs about how to config switch in IMC to work as intended, but this way port authentication for users stops working:
If I change service type to unlimited, 802.1x auth on ports works as intended, but admin-login does not. It treats my ADM account as an 802.1x one, and doesn't give proper priviliges, in UAM I cann see that it gives out normal vlan like it would on access port. Theres no enable command and so on.
I thought I can sidestep this, using secondary IP on interface and make it as a second entry in UAM - there I could specify unlimited and device managment service for each one separately. But it turns out 6100 model does not have all functions like secondary IP on interface or VRFs besides default.
