Good morning,
I am having issues with an upgrade to IMC. At first i was having database issues which I have gotten past but once the Performance Managament component gets to this part it fails. It looks like something to do with unzipping a file but if someone could help me interpret this I would be very appreciative. I can not Undeploy it and redeploy it either and IMC won't start because of this.
java.io.FileNotFoundException: C:\Program Files\iMC\client\web\apps\imc\resources\images\colorized\perf\Thumbs.db (Access is denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
at java.io.FileOutputStream.<init>(FileOutputStream.java:145)
at com.h3c.imc.deploy.tasks.UnzipFileTask$a.a(UnzipFileTask.java:289)
at com.h3c.imc.deploy.tasks.UnzipFileTask$a.doInBackground(UnzipFileTask.java:168)
at com.h3c.imc.deploy.tasks.f.call(SwingWorker.java:294)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at com.h3c.imc.deploy.tasks.SwingWorker.run(SwingWorker.java:333)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:662)
2018-04-05 08:46:30 [INFO ] [Thread-339] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK
2018-04-05 08:46:30 [INFO ] [ActiveMQ Session Task-8] [com.h3c.imc.deploy.dma.SlaveMessageHandler::onMessage(1231)] slave receive message: src=Slave_ALL; type=COMP_STATE_CHANGED_NOTIFY
2018-04-05 08:46:32 [INFO ] [ActiveMQ Session Task-8] [com.h3c.imc.deploy.dma.monitor.JmxMonitor::c(393)] JmxMonitor config reloaded, size = 3
2018-04-05 08:46:32 [INFO ] [pool-19-thread-1] [com.h3c.imc.deploy.dma.monitor.JmxMonitor::a(431)] Start monitor state file: ${instroot}/euplat/conf/.state
2018-04-05 08:46:32 [INFO ] [pool-19-thread-1] [com.h3c.imc.deploy.dma.monitor.JmxMonitor::a(431)] Start monitor state file: ${instroot}/client/conf/.state
2018-04-05 08:46:32 [INFO ] [pool-19-thread-1] [com.h3c.imc.deploy.dma.monitor.JmxMonitor::a(431)] Start monitor state file: ${instroot}/seplat/conf/.state
2018-04-05 08:46:32 [INFO ] [ActiveMQ Session Task-8] [com.h3c.imc.deploy.dma.SlaveMessageHandler::onMessage(1231)] slave receive message: src=Slave_ALL; type=QUERY_REMOTE_PROC
