Hi Folks,
I'm attempting to upgrade the previous installation and it seems to be taking forever. Installing on a Windows 2012 R2 VM and I'm seeing lots of log files being created in C:\Windows\IMC_Reserved\log, each file gets no lafrger than 2 KB and then it creates another and another, each with a timestamp extension.
I don't believe the 7.2 version is patched, should it be prior to starting the 7.3 upgrade?
Normal or something amiss??
Thanks in advance.
Buddy
