In the mean time I solved my issue.
As my UAM was runnig on a subordinate server, i have :
- Backup the EAD databebase
- Undeploy and Uninstal UAM
- get rid of all software and configuration bites.
- Re-install and Deploy E0601 base version
- Re-install and Upgrade with E0601P01 patch.
- Restore the EAD database.
Tough workaround, but with documentation close to none and no support, that the only thing which came to my mind.
But it was worth the try, as now eveything works again fine
The verification utility @:
User -> User Access Parameters -> Service Parameters -> Validate is now showing green without errors (that was not the case before)..
PS: The aruba ClearPass is superior to UAM in terms of pure network access control, however it lacks the integration with IMC or any other multivendor network management tool that we love.
Regards
Ray
However it
