Implementing 2 SSIDs (Employee and Guest)
  • 1.  Implementing 2 SSIDs (Employee and Guest)
    Posted Feb 16, 2020 08:53 PM
    Am kind of new to Aruba clear pass and controller so i need your kind help.
    I need to implement wired and wireless using dot.1x
    Here is what i did up to the moment but am still stuck
    1- joined the clear pass to AD
    2- Added the AD to clear pass as authentication source
    3- Added the controller as N A D on the clear pass and vice versa
    As per my customer requirement he needs 2 SS IDs 1 for the employee and 1 for the guest.
    The employee SS ID has 3 possibilities
    - The employee has corp PC and joined to domain plus its healthy (Full access)
    -The employee has corp PC and joined to domain but its not healthy (Quarantine )
    - The employee has personal laptop and want to access the internet with his domain controller credentials
    - The employee has mobile and wants to connect to the internet with his Domain controller credentials
    The issue now is i need your help to implement the services that match these rules on both sides Clear pass and Aruba Controller
    Note that the customer will assign the guest in V LAN 32 and the corp users in 33 and for the smartphones V LAN 31
  • 2.  RE: Implementing 2 SSIDs (Employee and Guest)
    Posted Feb 17, 2020 02:58 AM
    Hi there,
    There is probably not a "quick" answer to your question, if you are not too familiar with ClearPass just, yet.
    What I can highly recommend is the video series of my colleague @Herman Robers
    https://www.youtube.com/watch?v=wUK3BE7jMVY&list=PLsYGHuNuBZcb0xD05v9zdwv7NlUG_8oJS
    There are videos in the series, that explicitly talk about wired & wireless 802.1x with ClearPass.
    ClearPass has various service templates for different use cases, that might help with the initial configuration of ClearPass: https://www.arubanetworks.com/techdocs/ClearPass/6.8/PolicyManager/index.htm#CPPM_UserGuide/Services/ServiceTemplates.htm
    On the ArubaOS side it is quite "standard" 802.1x authentication.
    Maybe you can drop a few more specific questions, as the come along upon configuring the system.
