SD-WAN
  • 1.  Independent alarms per device & interface
    Posted Jan 22, 2024 10:35 AM
    Hi
    Is there going to be an implementation or feature added to allow for setting independent alarms per device instead of global? Example:
    Customer has a modem connected via LAN1 that is not always connected and sometimes removed. Will it be possible to disable the alarms for LAN1 only for that device to stop it creating alerts that aren't needed.
    Current alarms is to just disable the next-hop is unreachable but even then its a global change and not specific to this one device
    Matt
  • 2.  RE: Independent alarms per device & interface
    Posted Jan 24, 2024 01:31 AM
    Agree we need this but we don't have an immediate roadmap item lined up to suppress alarms on a per-appliance basis.
  • 3.  RE: Independent alarms per device & interface
    Posted Jan 24, 2024 03:46 AM
    The only workaround currently available is to use the REST API to periodically clear the alarms for these appliances using a script.
