  • 1.  Indoor as Outdoor
    Posted Feb 18, 2013 09:14 AM
    i want to use an indoor AP ( Ap93 ) in an out door area ,  area is small ( 5*6 Meters ) ....... is there any concerns ?  if i will geta box to protect AP from envirionmental issues ( water , air ....... )
  • 2.  RE: Indoor as Outdoor
    Posted Feb 18, 2013 09:30 AM
    If you have a box, it should be:
    - Waterproof
    - RF transparent
    - Temperature controlled
    - Resist changes in humidity
    This is not an endorsement from Aruba, but a few customers I know have used Oberonwireless successfully:  www.oberonwireless.com
  • 3.  RE: Indoor as Outdoor
    Posted Feb 18, 2013 11:51 AM
    Hi.
    Good evening,
    in Continues to cjoseph post.
    -u may also consider use a an AP with external antennas +Cable+LAR+Outdoor antenna and use outdoor antenna.
    -and then u don't need any box - deploy the AP inside an indoor/weather-proof environment (Building)
    (i have an old deployment like this of AP-60 units!! In -24c environment !! . THE AP units are located above this big cold warehouse in a good weatherproof environment .And only antennas and cables are located in the rough environment.)
    have a lovely week.
    Me
