  • 1.  Indoor/Outdoor APs
    Posted Nov 25, 2014 10:58 PM
    Hi.
    If you have an existing IAP environment with indoor APs can you add Outdoor APs in the same environment? Basically can the new outdoor APs join the cluster of the indoor APs?
  • 2.  RE: Indoor/Outdoor APs
    Posted Nov 25, 2014 11:05 PM
    Yes, as long as they share a L2 management segment and are running the same version of code.
