Currently i installed 6 IAP 225 in my client campus, due to the server room that connected to 4 among that 6 IAP does not have any POE+ switch, so i requets power injector from my client. But those power injector provided by my client initialy was used by IAP 105, i found that IAP 225 require 30watt to power up but the power injector i got from my client only 15watt. But those 4 IAP still able to power up.
Issue i encounter:
Among that 4 IAP, one of the IAP is master, in virtual controller, there are 3 SSID configured.
-Staff (Vlan 3, ip helper to dhcp server)
-Teacher(Vlan 8, ip helper to dhcp server)
-Guest(Vlan 16, using local dhcp from virtual controller)
For staff and teacher ssid work fine but when i try to connect guest, I found that i cant get any ip address. Possible the power injector affect the IAP performance? So it unable to provide IP address?
P/S: I tried before if the master was connected to POE+ switch, i able to connect to guest and also able to get IP address.
#AP225
