  • 1.  Install a Certification for Aruba Controller
    Posted Jun 20, 2017 10:00 AM
    Hi ,
    how can i generate a certifcate from Windows server to be used in the controller for 802.1X , Captive Portal and Secure Login
    Regards
  • 2.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 10:09 AM
    You need to use a public CA-signed certificate for captive portal functions, not a private one.
  • 3.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 10:22 AM
    ok for the captive portal , what about the 802.1X authentication ?
  • 4.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 11:01 AM
    You’re not using a RADIUS server?
    What is the mix of clients?
    Managed or unmanaged?
    What EAP method are you planning to use?
  • 5.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 12:20 PM
    l'm going to use Radius Server with EAP terminition, witch mean that ihave to install a certifcate in the controller to avoid the error message.
    i'm going to use a windows server as CA certifcate
  • 6.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 12:22 PM
    You should terminate on the RADIUS server.
    Are all of your clients fully managed?
  • 7.  RE: Install a Certification for Aruba Controller
    Posted Jun 20, 2017 12:33 PM
    I have two Radius Server and it needs EAP terminition as you know.
    know  how to do it :)
  • 8.  RE: Install a Certification for Aruba Controller
    Posted Jun 21, 2017 07:52 PM
    i found the this document and i solve my probleme , please don't miss to install the root certification in your controller in the root cetification repository directly or via a GPO
    Attachment(s)
    pdf
    Apr MHC Aruba Cert.pdf   661 KB 1 version
