Network Management
  • 1.  Installation-log says SQLServer 2014 is not installed, why?
    Posted Mar 19, 2016 12:45 PM
    OS: Windows 2012 R2 64 Edition
    Microsoft SQL Server 2014 SP1 CU5 installed (Version 12.0.4439.1)
    I have a completetly new Windows 2012 R2 64 server with all Microsoft updates applied.
    I have installed MS SQL Server 2014 SP1 with CU5 and done the changes according to "HP IMC Installation SQL 2014.pdf".
    Then I downloaded iMC_PLAT_7.2_E0403_Std_Win and started the installation. But when it comes to checking for databases the GUI says that there is no database available. The log says the following:
    "[com.h3c.imc.deploy.dma.monitor.DatabaseConnectMonitor::run(74)] start check database connect...
    2016-03-19 16:51:20 [INFO ] [iMC-Database-Connect-Check] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(168)] Start loading server-addr.xml configuration file
    2016-03-19 16:51:20 [WARN ] [iMC-Database-Connect-Check] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(173)] Config file is not exist - D:\Program Files\iMC\common\conf\server-addr.xml
    2016-03-19 16:51:20 [ERROR] [iMC-Database-Connect-Check] [com.h3c.imc.deploy.dma.monitor.DatabaseConnectMonitor::run(74)] Can not found database.
    2016-03-19 16:51:20 [INFO ] [main] [com.h3c.imc.deploy.dma.DeployManager::a(786)] Component deploy state changed
    2016-03-19 16:51:20 [INFO ] [ActiveMQ Session Task-1] [com.h3c.imc.deploy.dma.AgentMessageHandler::a(1078)] Receive master state change message: Connected
    2016-03-19 16:51:20 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.ComponentDeployInfo::isComponentsConformable(606)] Components conformable check failed: no component deployed
    2016-03-19 16:51:50 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DeployWizard$WizardData::a(434)] Deploy component "iMC-PLAT" for the first time: true
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(95)] data.isNeedSelectDatabase() is : true
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(96)] data.isNeedInputWebServerPort() is : true
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(97)] data.isNeedShowCustomPanels() is : false
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(372)] SQLServer 2000 is not Installed
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSqlServerInstalled(1040)] SQLServer 2005 is not Installed
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::c(458)] SQLServer 2008 is not Installed
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::d(506)] SQLServer 2012 is not Installed
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::e(554)] SQLServer 2014 is not Installed
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::aboutToDisplayPanel(287)] Need to install SQL Server 2008 R2 Express
    2016-03-19 16:51:51 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::checkDotNetVersion(610)] .Net Framework 2.0 SP2 is Installed"
    What should I do to make the installation software understand that I have SQL2014 SP1 installed?
    I have made the recommended changes in the Sql Server Configuration Manager, putting the IP addresses to "enable". I have changed so that the SQL Server service is using LocalSystem. I have started the SQL Server Browser service. I have disabled the firewall.
    What have I missed?
    Another question: If I decide to install the software with the SQL 2008 Server Express, can I easily change and move the database to SQL2014 SP1 once I discovered what I am doing wrong?
    #windows2012r2
    #SQLServer2014
    #iMCV7.2
  • 2.  RE: Installation-log says SQLServer 2014 is not installed, why?
    Posted Mar 19, 2016 02:26 PM
    Seems like HP just don't want me to have any success with this...
    I uninstalled SQL2014 completely and made a clean start trying to install iMC. After the stage where it has installed SQL 2008 R2 Express the installation fails and the log says:
    "Begin to install database and data...
    Begin to create config_db database...
    'osql' is not recognized as an internal or external command,
    operable program or batch file."
    Any ideas why osql is not found as a command? If you look at the attached screenshot, if I in a command prompt write osql I get a response, and in my PATH environment it is pointing to "C:\Program Files\Microsoft SQL Server\100\Tools\Binn".
    Any ideas?
  • 3.  RE: Installation-log says SQLServer 2014 is not installed, why?
    Posted Mar 19, 2016 02:54 PM
    I tried on a diffrerent computer that is running the older Windows 2012 OS, but also have SQL Server 2014 SP1, and there it worked without a problem, see attached screenshot.
    Could somebody confirm that Windows 2012 R2 is not a problem to use for iMC?
  • 4.  RE: Installation-log says SQLServer 2014 is not installed, why?
    Posted Mar 19, 2016 03:02 PM
    Finally got it to work!
    I un-installed everything, wiped folders, wiped registry-settings etc.
    Then installed SQL2014SP1 again and then iMC recognized that the database was there and asked for credentials, so I am happy again.
