Skip main navigation (Press Enter).
Log in
Toggle navigation
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
Threat Labs
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Comware
Community Home
Discussion
56.9K
Members
815
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Installation of J4859B on J4908A Module
Brad Paulus
Apr 28, 2007 08:24 AM
Looking for instructions or procedure to install the J4895B GBIC. The J4908A module sees the GBIC in ...
Jonathan Axford
May 01, 2007 11:17 AM
Hi, Did the switch get rebooted when the module (and GBIC) were installed? If not, it may need to ...
1.
Kudos
Brad Paulus
Posted Apr 28, 2007 08:24 AM
Reply Privately
Options Dropdown
Looking for instructions or procedure to install the J4895B GBIC. The J4908A module sees the GBIC in the slot, but does not have an indication that it is active on the modules port status.
2.
RE: Installation of J4859B on J4908A Module
Kudos
Jonathan Axford
Posted May 01, 2007 11:17 AM
Reply Privately
Options Dropdown
If not, it may need to have this done before the GBIC interface can be configured.
Does the switch allow you to access the interface to configure it?
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
installing GBIC
Chris Bullock_1
Added Aug 07, 2006
Discussion Thread
4
5940 Can't install the packet capture module
AntoAdv
Added Aug 10, 2023
Discussion Thread
1
How to install Local Connect Module ?
Horly
Added Sep 04, 2017
Discussion Thread
4
J4908a GBIC Port and Trunk
Integer
Added Jan 23, 2009
Discussion Thread
5
7750 Gigabit Module Installation
rambo888888
Added Mar 08, 2010
Discussion Thread
2
Copyright 2024. All rights reserved.
Powered by Higher Logic
