Network Management
  • 1.  Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 09:49 AM
    Edited by dschug Nov 27, 2024 11:38 AM
    I'm trying to install Airwave (tried 8.3.0.3 and 8.2.15.2).
    I tried several USB Sticks and Software creating Bootable Sticks (unetbootin, rufus, etcher)
    Everytime starting Installation it gets stuck on random: crng init done
    I also tried Bios and UEFI Boot, but UEFI just shows Grub.
    Wasted several hours now and can't figure out a solution.
  • 2.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 10:23 AM
    Bootable DVD and USB drives are currently not supported for AirWave 8.3.0 installation.
    See attached Installation Guide.
    Attachment(s)
  • 3.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 10:35 AM
    And what about 8.2.15.2? Its the same Issue.
  • 4.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 10:42 AM
    Since 8.2.x Version is End-of-Support, I would avoid installing this.
  • 5.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 10:49 AM
    Since its a Version we use (15+ Airwaves in sum) and some Machines don't Support Local Iso or Virtual Disc, I still need a solution.
    Out of Support won't help us.
    So my goal is to install this Version in first instance. I just tried 8.0.3.2 to exclude any issues with the iso.
    So why does USB Stick not work. But a DVD worked last time (is not an option, because we can't burn DVDs anymore)
  • 6.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 11:07 AM
    With Out od Support I only want to mention that it makes more sense to focus on 8.3. Code Train.
    Let´s start from the beginning to get the full picture.
    On what device are you trying to install AirWave?
    Is it an official AirWave HW Appliance?
  • 7.  RE: Installing Airwave via USB Stick Issues
    Posted Nov 27, 2024 11:22 AM
    Edited by dschug Nov 27, 2024 11:22 AM
    Understood with Out of Support, its on our Agenda.
    So I try to get a quick win, since our Machines are getting Full of devices, I got a AW-HW630-ENT (96 GB RAM) from Aruba we saved and yes we are aware its out of Hardware Support.
    I already installed 3 of these, but with DVD. Since I got no DVDs nor a burner, i have to rely on a USB Stick.
