There is a known issue CP‑49373/CP‑49665: the configured HTTP Proxy settings were not used when downloading ClearPass Extensions.
Fixed in 6.11.3 (so alexs-nd, please open a TAC case if you see this on 6.11.4);
https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.x.x/Default.htm#ReleaseNotes/Resolved/Resolved-6.11.3.htm?Highlight=49373
This issue seems to be in 6.10 as well, so maybe also in 6.9 but I can't find the full details on versions. Best would be to open a TAC case as they seem to be able to fix this issue for you.
Original Message:
Sent: Oct 13, 2023 05:39 AM
Subject: Installing intune extension failed on clearpass with proxy settings
We are currently running clearpass cluster with version 6.9.13 and want to make an integration with Microsoft Intune. Our cluster is behind a firewall that normally has no internet access. We use a proxy server to retrieve firmware updatec, etc. Downloading firmware etc works fine with a proxy server.
Now we want to install the Microsoft Intune extension and get the following error message: Error creating extension instance: Download failed with status 500.
When we make a wireshark trace, we see that clearpass wants to go directly to the internet and not via the proxy server. According to the clearpass documentation, the proxy settings of the cppm should be inherited.
Is anyone familiar with this problem?
