Hi Everyone,
I have a stack of 2930M managed via template group in Central. I'm working to add dot1x, and as part of this I'd like to use DURs. There is a requirement to have the switch trust the CA which issued ClearPass HTTPS certificate. The instructions suggest you need to add a 'crypto pki ta-profile ABCD' and then do
'copy tftp ta-certificate ABCD 192.168.1.x godaddy.cer'
However the 'crypto pki ta-profile' is not part of show run, so i can't seem to add it that way via template, and if i try to do 'copy' on the switch there is no tftp or sftp option. The Central guide only talks about IAP and templates with certificates, i can't seem to find it related to Switches?
Thanks!
