  • 1.  Instant 8.6.0.0 ekahau measurement
    Posted Nov 19, 2019 11:51 AM
    Is it possible to configure an AP-505 in instant mode without checking the uplink status?
    I would like to use this AP to do a wifi mearurment using Ekahau.
    The problem nog is that the AP keep rebooting because it misses the uplink.
    I've tried to change the uplink enforcement in the CLI, but it doesn't seem to change...
    b8:3a:5a:c0:0c:50# show ap-env
    Antenna Type:Internal
    Need USB field:Yes
    ipaddr:192.168.166.1
    netmask:255.255.255.0
    gatewayip:192.168.166.254
    dnsip:8.8.8.8
    usb-port-disable:1
    ap1xuser:admin
    ap1xpasswd:a04ffb9fc4a5894b91d706aaa5aedcbcd566b17295ab6456
    uap_controller_less:1
    b8:3a:5a:c0:0c:50#
    b8:3a:5a:c0:0c:50# sh ver
    ArubaOS (MODEL: 505), Version 8.6.0.0
    Website: http://www.arubanetworks.com
    (c) Copyright 2019 Hewlett Packard Enterprise Development LP.
    Compiled on 2019-11-09 at 11:02:10 UTC (build 73143) by p4build
    FIPS Mode :disabled
    AP uptime is 7 minutes 34 seconds
    Reboot Time and Cause: AP rebooted Sat Nov 9 11:07:45 UTC 2019; System cmd at uptime 0D 0H 8M 55S: Current uplink down, no useable uplink
    b8:3a:5a:c0:0c:50#
    Brgds,
    Rob Hassing
  • 2.  RE: Instant 8.6.0.0 ekahau measurement
    Posted Nov 21, 2019 08:44 AM
    here is an older post, maybe it can help:
    https://community.arubanetworks.com/t5/Wireless-Access/Site-Survey-with-IAP-Manual/m-p/57274/highlight/true#M549
    Additionally i wanted to reproduce your Problem, but i can't. I've taken an AP-515 (out-of-the-box), upgraded to 8.6.0.0., set a ssid, put in a dc-power-supply, put out the lan-cable...it runs about 20min without reboot...mhh.
  • 3.  RE: Instant 8.6.0.0 ekahau measurement
    Posted Nov 21, 2019 09:05 AM
    Need USB field:Yes
    dnsip:8.8.8.8
    usb-port-disable:1
    ap1xuser:admin
    b8:3a:5a:c0:0c:50#
    FIPS Mode :disabled
    b8:3a:5a:c0:0c:50#
    Brgds,
    Rob Hassing
    Can you remove the AP802.1x configuration and try this with a "Vanilla" config?
