Afternoon,
In order for a client to roam within an Instant mobility domain, it is stated that the "WLAN access parameters" must be the same across the layer 3 networks. I understand the configuration of the mobility domain, which seems straightforward, however I would like confirmation of what is meant by identical WLAN access parameters.
Does this refer to the SSID and its associated authentication method, meaning that a client can only roam at layer 3 if the same SSID and authentication are configured across the clusters/swarms in the mobility domain?
Are there any other configurations that need to be consistant across clusters in the mobility domain?
Johnny.
