Cloud Managed Networks
  • 1.  Instant AP settings
    Posted Jul 14, 2021 12:11 PM
    Hi there.
    Does anyone know anything about the following for Access Point and Radio settings?
    What do they mean and what the best settings should be?
    Background Spectrum Monitoring = On or Off ?
    Channel Quality Threshold = ? …. Channel Quality Wait time = ?  ... what is the recommendation?
    Smart Antenna = On or Off ?
    Thanks in advance.
    Kianoosh Nazem
  • 2.  RE: Instant AP settings
    Posted Jul 14, 2021 11:54 PM
    you can check this URL to get some explanation
    https://www.arubanetworks.com/techdocs/Instant_87_WebHelp/Content/instant-ug/arm/conf-radio-sett.htm?Highlight=%22Channel%20Quality%20Threshold%22
    smart antenna are used in only IAP-335s so if you don't have that, don't use it.
    i would leave the channel quality , etc to their default value and only change base don recommendation from TAC.
    but here you can find what they mean.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/rf-arm-pro.htm?Highlight=Channel%20Quality%20threshold
  • 3.  RE: Instant AP settings
    Posted Jul 15, 2021 04:14 AM
    Also, don't forget to look at the Instant Validated Reference Design Guide as these give you the best practice as to when to enable/disable the settings.
    Craig Syme
