  • 1.  Instant - Captive Portal possibilities (AD Login/device caching)
    Posted Jun 15, 2017 12:53 PM
    Hi all, need someone to refresh my memory.
    1. Can instant captive portal do AD auth or is it only local user based?
    2. Also, can instant captive portal do mac/user caching so they do not have to login again?
    I know ClearPass can do this, but cant remember the basic functionality for Instant.
    -N
  • 2.  RE: Instant - Captive Portal possibilities (AD Login/device caching)
    Posted Jun 16, 2017 07:03 AM
    1. Instant captive portal supports AD auth via either LDAP or RADIUS.
    2. Yes, but you'll need an authentication server that stores the list of users/MAC addresses such as ClearPass.
  • 3.  RE: Instant - Captive Portal possibilities (AD Login/device caching)
    Posted Jun 21, 2017 11:47 AM
    So I was able to get this to work but it seems like any AD auth via the captive portal only uses PAP. Is there a way to change this?
    N
  • 4.  RE: Instant - Captive Portal possibilities (AD Login/device caching)
    Posted Jun 21, 2017 08:03 PM
    Captive Portal requires pap.  The username is in clear text, but the controller encrypts the user password using the RADIUS shared secret.  That is why it is important to choose a complicated radius shared secret.  If you want better encryption, you should move to 802.1x.
