Instant - Cellular 4G Huawei E3276S
  • 1.  Instant - Cellular 4G Huawei E3276S
    Posted Nov 21, 2014 04:57 PM
    I have an RAP-155 and having trouble to get i working with a 4G usb dongle.
    Modell: Huawei E3276s - 150 and this should be supported according to the documentation.
    http://www.arubanetworks.com/support-services/interoperability/#3GEVDOUSBModemsforRemoteAccessPoints
    The RAP detects the modem correctly, the strange thing is from the show cellular config and supported isps and countrys and this make me curious how this work?
    I have also tried a couple of different manual provision settings, in all sorts of combinations.
    Any help, suggestions or explantions are welcome.
    Type Value
    4g-usb-type
    usb-type huawei-cdc
    usb-dev 0x12d11506
    usb-tty
    usb-init AT+CGDCONT=1,"IP","4g.tele2.se"
    usb-auth-type CHAP
    usb-user
    usb-passwd
    usb-dial ATD*99#
    usb-modeswitch
    modem-isp
    modem-country
    show cellular status
    cellular status
    card detect link
    Present detect-ok Linkdown
    USB Modem Information
    Parameter Value
    Manufacturer HUAWEI
    Product HUAWEI Mobile
    Serial Number
    Driver (none)
    Vendor ID 12d1
    Product ID 1506
    Supported Country list
    Country list
    China
    UK
    Germany
    India
    Supported ISP list
    ISP list
    China Unicom
    Vodafone
    T-Mobile
    Airtel
    modem status summary:USB modem attached with detect successful
  • 2.  RE: Instant - Cellular 4G Huawei E3276S
    Posted Jan 12, 2015 09:55 AM
    Did you got this working? I have the same issue?
    Kr,
  • 3.  RE: Instant - Cellular 4G Huawei E3276S
    Posted Jan 12, 2015 10:40 AM
    sorry, no...
  • 4.  RE: Instant - Cellular 4G Huawei E3276S
    Posted Jan 15, 2015 06:05 AM
    Good news, I received configuration from TAC for an IAP (RAP-3WN):
    (Country: Belgium and ISP: Proximus: not supported by default)
    00:0b:86:b9:25:a6# show cellular config
    Comm USB Plugged in: Vendor_ID=12d1 Product_ID=158e
    Cellular configuration
    Type            Value
    4g-usb-type     huawei-cdc
    usb-type        huawei-cdc
    usb-dev         0x12d1158e
    usb-tty
    usb-init
    usb-auth-type
    usb-user
    usb-passwd
    usb-dial        ATDT*99***1#
    usb-modeswitch
    modem-isp
    modem-country
    Country list
    Supported ISP list
    ISP list
    00:0b:86:b9:25:a6# show cellular status
    cellular status
    card     detect     link
    Present  detect-ok  Linkup
    Parameter      Value
    Manufacturer    HUAWEI
    Serial Number   FFFFFFFFFFFFFFFF
    Driver          huawei_ether
    Vendor ID       12d1
    Product ID      158e
    Cellular Link Status
    Parameter                 Value
    USB Modem State            Active
    USB Uplink RSSI(in dBm)    -65
    Current Network Service    4G-LTE
    Ethernet Uplink really should be disconnected, otherwise the dongle won't register to the network.
    EDIT: Also an other remark: there are 2 types of Huawei E3276 so if you have the other type (other Product_id) you can try with changing the usb-dev to 0x12d1xxxx with xxxx=Product_id
    kind regards,
