Instant - Min / Max Transmit power vs Min / Max power?
  • 1.  Instant - Min / Max Transmit power vs Min / Max power?
    Posted Jan 17, 2017 09:49 PM
    Can anyone explain the difference between these two config parameters and when you would want to configure each?
    RF -> ARM -> Min Transmit Power, Max Transmit Power
    RF -> Radio -> Customize ARM Power Range [2.4GHZ | 5GHz] -> Min Power, Max Power
    Also how to these relate to Aruba's recommended power levels from the VRDs?
  • 2.  RE: Instant - Min / Max Transmit power vs Min / Max power?
    Posted Jan 18, 2017 04:07 AM
    The per band (2.4 / 5GHz) has been introduced recently to allow different ARM power settings per band, so you can set the power on 5 GHz slightly higher over 2.4 like advised in the VRDs.
    The RF -> ARM is a global setting, so it applies to all radios.
    I just tested in my lab, and what happens is that if you have set the RF -> Radio -> Customize ARM Power range, that setting will take precedence. If you have not set it for the specific band, the setting in RF -> ARM -> Min/Max transmit power will be set.
    You can also set static channel+power on the AP itself in the Radio tab. That will disable ARM for that radio(s), and configure static settings.
  • 3.  RE: Instant - Min / Max Transmit power vs Min / Max power?
    Posted Jan 18, 2017 02:13 PM
    Thanks this is exactly what I was looking for!
