Instant v.4.1 Released!
pmonardo
pmonardoJun 10, 2014 11:12 AM
pmonardo
pmonardoJun 10, 2014 11:12 AMBest Answer
  • 1.  Instant v.4.1 Released!
    Posted Jun 10, 2014 02:58 AM
    Instant v.4.1 has just been released!
    This is a major release with exciting new features!
    Be sure to check out the "Recent IAP Releases" thread here for an over view.  Be sure to download the Release Notes and new Users Guide as well.
    As always, with Major new releases this will be posted for download on the TAC site only and will migrate to the cloud later.
  • 2.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 11:12 AM
    iap-93 will not support AppRF. nor will the 105.
  • 3.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 11:14 AM
    So, I can upgrade it to this firmware version but they don't support AppRF, right?!
  • 4.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 11:54 AM
    As the release notes says , don't upgrade the 93/92 to v4.1 since is not supported.
    2014-06-10 11_53_21-Aruba Instant 6.4.0.2-4.1 Release Notes - Adobe Reader.png
  • 5.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 12:24 PM
    I wonder if and at what firmware version the IAP-104/105 will not be supported.
  • 6.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 12:27 PM
    Nothing is planned for the moment.  Only the IAP-9x end of support is known.......it was a low-end / low-cost AP and was running out of resources.
  • 7.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 03:07 PM
    Hi Marcus,
    Which version of code do we download for IAP-103? I assume it is the same Orion version as the 93,105?
    Can you confirm? If so can the support site be updated?
  • 8.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 03:11 PM
    For 103, please download the image file with the name ?Pegasus? in it.
    Yan
  • 9.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 03:15 PM
    Thanks yan!
  • 10.  RE: Instant v.4.1 Released!
    Posted Jun 11, 2014 09:49 AM
    What is the minimum Airwave version required to support IAP 4.1. (not the IAP gui support)
    With AMP 7.7.10, I only see the VC and not the APs when it is connected to AIrwave. I have seen this similar when using 4.0 on AMP 7.6
    Does it require 8.0?
    EDIT: small edits
  • 11.  RE: Instant v.4.1 Released!
    Posted Jun 11, 2014 01:27 PM
    AirWave 8.0 is required for IAP 4.1.  The IAP GUI Config (IGC) and AppRF display in AW, however, will not be supported for 4.1 until AW 8.1 is released which is 3 - 6 weeks out.
    Unfortunately, the Release Notes and Supported Devices documentation are not really clear on this but I confirmed it with engineering.
  • 12.  RE: Instant v.4.1 Released!
    Posted Jun 11, 2014 02:14 PM
    That's what I figured. Thanks Marcus for confirming.
  • 13.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 11:57 AM
    I don't want to be to be insistent, but I do this question because in the USER GUIDE of the new version i see what I attach inthe file.
    Thanks!
  • 14.  RE: Instant v.4.1 Released!
    Posted Jun 10, 2014 11:59 AM
    ~~~ EDIT ~~~ I listed the wrong version number in my post earlier.  It is correct now.....
    The IAP-9x is -not- supported in 4.1.0.0 at all.   Support for the IAP-9x will be added in 4.1.01 but with the limitations noted and they will not have AppRF in any form.  Also, v.4.1.x.x will be the last version for the IAP-9x.
  • 15.  RE: Instant v.4.1 Released!
    Ok, thanks victor! I read your post only now!
    Thanks you too, Marcus!
  • 16.  RE: Instant v.4.1 Released!
    SNMP bug fixed too!!
  • 17.  RE: Instant v.4.1 Released!
    ya AppRF!!!
  • 18.  RE: Instant v.4.1 Released!
    Hi Marcus,
    I have read the release notes but I still have a doubt: it is possible to upgrade to this version the IAP-92/93? Or they only don't support the AppRF tools?
    Massimo
  • 19.  RE: Instant v.4.1 Released!
    Posted Jun 12, 2014 09:50 AM
    Any time frame on when v4.1 will be supported for deployment via the Cloud Wi-Fi?  Is it possible to touch each device and update them or would that not be supported at this time?
    One other thing the Access Control based on Web Category wondered how that list is updated or does that require OpenDNS licenses to function?
  • 20.  RE: Instant v.4.1 Released!
    Posted Jun 12, 2014 09:58 AM
    I don't believe it requires an OpenDNS license for that.
  • 21.  RE: Instant v.4.1 Released!
    Posted Jun 13, 2014 03:47 AM
    Aruba Central will be updated to fully support IAP v.4.1 over the next few weeks.
    There are now two web-content filtering techniques in IAP and it can be easy to confuse the two: OpenDNS and the new web-categorization (uses BrightCloud on the backend).
    OpenDNS requires a subscription directly with OpenDNS.
    The web-categorization feature of AppRF will require an IAP feature license.
    Keep in mind that IAP AppRF is two parts: native DPI that can identify ~1,500 applications + web-categorization. The native DPI portion of AppRF does not require anything and is free.
  • 22.  RE: Instant v.4.1 Released!
    Posted Jun 13, 2014 08:39 AM
    License for Instant? How will that work?
  • 23.  RE: Instant v.4.1 Released!
    Posted Jun 13, 2014 08:53 AM
    Will the feature license be perpetual or a yearly subscription for the web categories?
    Will this stay just with the IAP line or will the Controller route get this as well?
    Was looking forward to the AppRF by itself but the AppRF with Web Categories would be nice.
  • 24.  RE: Instant v.4.1 Released!
    Posted Jun 13, 2014 09:17 AM
    It will be in the next AOS release.
  • 25.  RE: Instant v.4.1 Released!
    Posted Jun 14, 2014 02:09 AM
    Hello Marcus
    How cpu and memory intensive is the APPRF on the instant APS?
    Im just trying to imaging the big picture of it on a production enviroment which has plenty instants APs in a cluster
    How we can know well we can turn it without issues...
    And when we can know well we CANT turn it because it will bring us issues with the IAP resourses.
    Cheers
    Carlos
  • 26.  RE: Instant v.4.1 Released!
    Posted Jun 14, 2014 06:27 PM
    AppRF in instant is a completely distributed solution where there is no interaction between the Aps in a cluster with regards to AppRF. Each AP does AppRF for its connected clients. Hence, there is no relation with Apprf scalability and cluster size so you should be able to enable it on large clusters without concern.
    Under normal network load – typical deployments with 16 clients per AP – DPI module’s CPU utilization is very minimal even when classifying lot of sessions. However, DPI processing is tied to IAP’s dynamic CPU management to ensure that this processing in a loaded system does not affect control plane or management plane traffic.
  • 27.  RE: Instant v.4.1 Released!
    Posted Jun 16, 2014 11:15 AM
    Thank you very much Marcus!!
    Cheers
    Carlos
  • 28.  RE: Instant v.4.1 Released!
    Posted Jun 13, 2014 09:15 AM
    Details on the Web categorization feature licensing are still being finalized. It will appear as a part number in the price list. Stay tuned. .....
