InstantOS compatability
  • 1.  InstantOS compatability
    Posted Feb 19, 2016 02:10 PM
    I am  planning to  deploy  IAP-325(indoors) with  IAP-275(outdoors)
    and  as we  know that new  325 model  will  start from  InstantOS 4.2.2.0 and can not be degraded and i am  not sure that IAP-275 can be  upgraded to  4.2.2.0 can  any  clarify/answer this   ??
    Second  what if i donot  upgrade iap-275 and  donot  downgrade iap-325 will  this  mix and match  of instantOS will  work  without any  bug or  problem
  • 2.  RE: InstantOS compatability
    Posted Feb 19, 2016 02:12 PM
    Yes, you can upgrade the 275. All IAPs in the cluster must have the same version.
