As I mentioned I have kept only below files out of which 2 are current, is it ok ? Because in my switch below two files are showing as current !
Original Message:
Sent: Jul 26, 2023 06:40 AM
Subject: Insufficient Space - HPE 5510 Switch
As Ian wrote. Do not delete current version of .bin files like 5510hi-cmw710-boot-r3506p02.bin and 5510hi-cmw710-system-r3506p02.binWhat are current main and backup boot files you can check with display boot command.
And do not forget to delete files on all members of the stack.
display irf
will show you stack members if any.
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Jul 26, 2023 06:30 AM
OK!
Original Message:
Sent: Jul 26, 2023 06:19 AM
You can delete any IPE file.
You can delete any BIN file that is not the current version.
You should use the delete /unreserved version of the command if available.
You should delete the file from all members of the IRF
Original Message:
Sent: Jul 26, 2023 06:10 AM
Can I delete all the below files
0 -rw- 80640000 Jan 01 2013 06:05:02 5510HI-CMW710-R1309P07.ipe
1 -rw- 92079104 Jan 10 2013 07:24:14 5510HI-CMW710-R3507P03.ipe
2 -rw- 10720256 Aug 09 2008 01:30:00 5510hi-cmw710-boot-r1122p02.bin
3 -rw- 6810624 Jan 01 2013 06:16:00 5510hi-cmw710-boot-r1309p07.bin
4 -rw- 7171072 Jan 19 2013 05:41:21 5510hi-cmw710-boot-r3506p02.bin
6 -rw- 1008640 Jan 19 2013 05:42:04 5510hi-cmw710-freeradius-r3506p02.bin
7 -rw- 61771776 Aug 09 2008 01:30:00 5510hi-cmw710-system-r1122p02.bin
8 -rw- 73822208 Jan 01 2013 06:16:35 5510hi-cmw710-system-r1309p07.bin
9 -rw- 83584000 Jan 19 2013 05:42:03 5510hi-cmw710-system-r3506p02.bin
Original Message:
Sent: Jul 24, 2023 09:39 AM
You have two .ipe files on your flash as per your snapshot. Delete them.
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Jul 24, 2023 09:07 AM
IT has no .ipe files
file are as below
xxxxxxx.boot-r1122p02.bin
xxxxxxx.system-r1122p02.bin
You can see in my previous screenshots also.
Please advise
Original Message:
Sent: Jul 24, 2023 08:47 AM
You need to delete all .ipe files and .bin files for version r1122p02.
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Jul 24, 2023 08:40 AM
Kindly find the details and advise as to which files can I delete. Trash is not available !
Original Message:
Sent: Jul 24, 2023 06:00 AM
Hi, you are running the same version as one of my switches and it is also a 5510. I can run the following commands:
- dir /all-filesystems
- dir
- dir .trash
But likely just dir will be enough to see if you have unused files. Once you have identified which files are to be deleted use a command like this:
- delete /unreserved flash:/5510HI-CMW710-R3506P11.ipe
Original Message:
Sent: Jul 24, 2023 05:44 AM
I have gone through the same but in my switch it does not support dir /all due to this I am not able to see all the files so I can identify unwanted files!
Yes I could see the below details which is not sufficient to delete unwanted files, I hope so, please advise
Original Message:
Sent: Jul 24, 2023 05:20 AM
Yep, I recall just one old thread (above many others threads) about freeing space on Comware flash, it was (is, still) on the (now defunct) HPE Community - Networking Forum, look, as example, at this one.
Original Message:
Sent: Jul 23, 2023 01:50 PM
For comware, I have to delete old firmware before loading new. Old files are not deleted automatically. I haven't had to delete log files or current bin files.
One thing that isn't well advertised is that if you delete a file by default it goes in the .trash folder. Using the /unreserved parameter on the cli avoids that.
So deleting all IPE files, non current bin files and all of the trash folder has always resolved this issue.
Original Message:
Sent: Jul 22, 2023 05:03 AM
I am updating the firmware for our HPE 5510 L3 switch but as soon as I apply, it gives error as below. Kindly advise as to how to resolve
