Network Management
Interface Alarm Filter for SNMP connected devices?
  • 1.  Interface Alarm Filter for SNMP connected devices?
    Posted Jun 04, 2013 04:10 AM
    In system settings you can filter Alarms for PC-connected, server-connected and disconnected links but there is no option to filter for SNMP Device-connected Interface.
    Is there another place where this is set as I am getting alarms for SNMP Device-connected Interface like access points even there it is set to system settings filter when looking at the actual device interface list.?
    #snmp
  • 2.  RE: Interface Alarm Filter for SNMP connected devices?
    Posted Jun 05, 2013 08:14 PM
    I don't think there's any easy way of doing it. You might end up needing to create Port Groups, and then run a Batch Operation on those port groups.
    If you've got some consistency with the interface Alias configured for those ports connected to the APs - e.g. a description like "AP xxxx", then you can use that to help with searching for interfaces to add to the group.
    It's definitely something that should be tidied up within IMC though.
